Viewing 1 reply thread
    • #44215
      thomas mitchell
      This is my first balanced lug rig.  The plans show a large hole in the hook aft of the mast and a small hole on the forward edge.  The line from the large hole appears to lead over the boom and then to the cleat on the mast.  I assume that it is a vang or downhaul.  However if it is too tight it would limit the outward swing of the boom.  What is the best setting for this line?  Also, what is the function of a line through the small hole in the hook?
    • #44305
      Tom – I use the small hole to run a light line around the front of the mast… I’m sure there is a technical name for it, but it just keeps the boom up against the mast.
      the larger hole is for a “down haul” line for the boom  that you would cleat off on one of the two cleats on the mast.
      I am sure there are real sailors that can chime in with more knowledge than I have about sailing and rigging!
