Home › Forums › 11′ 10″ ARRIBA / OONAGH Dinghy – Official Step-by-Step Boatbuilders’ Forum › ARRIBA / OONAGH – 26 – Gear & Outfitting › Outboard considerations
- This topic has 6 replies, 2 voices, and was last updated 1 year, 7 months ago by
Ted Guild.
April 16, 2022 at 11:30 am #46343
Ted Guild
ParticipantI’m building from plans, not kit and currently on bulkheads but soon will be cutting stern for the rudder.
In the videos Kit mentioned she cut the transom a bit lower since the owners were going to keep a Torqeedo on it. Presumably off set a bit so it can be raised, rudder attached and sail. I’ll be getting the same motor but don’t think I’ll mind taking it off and on. I won’t be leaving it on while moored and also want to get good at rowing. The motor will just be a third power option when wind dies down and I don’t want to paddle all the way back.
Anyone here using an outboard on theirs and have any recommendations?
April 3, 2023 at 12:07 pm #47701
Ted Guild
April 3, 2023 at 12:09 pm #47702
Ted Guild
ParticipantAs I thought, the motor might be an issue for the traveler. Anyone using an outboard and come up with a solution?
I’m thinking my only option to be able to sail with motor mounted would be to go boomless, not have a traveler and move the block each time I come around like Roger Barnes does in his videos.
Open to suggestions
November 14, 2024 at 11:19 pm #51439
Tim Economu
ParticipantI’m planning on using the X5 series Golden Motor outboard.
Both the Golden and Epropulsion can use an owner battery pack.
EZoutboard eXtreme EZ-X05 (3 KW) 5 Horsepower
Tim
November 20, 2024 at 12:53 pm #51596
Ted Guild
ParticipantI had to leave the traveler longer than I would have preferred but it works. Often I remove the battery from the motor when under sail which helps and allows me to put a bit of weight forward.
November 23, 2024 at 8:25 pm #51644
Tim Economu
ParticipantTed where do you keep the battery normally? Care to share any pics of the “battery compartment’?
Thanks!
Tim
November 24, 2024 at 12:48 pm #51662
Ted Guild
ParticipantThe battery from my Epropulsion motor fits in either of the center bench compartments when under sail.
It certainly would store in the stern compartment but you’ve probably seen the thread about keeping a better line when sailing when there isn’t too much weight rearward. I sit on the floor when sailing and getting the battery to switch back to motoring is fairly easy. It would be more of a scramble to get it out of the bow compartment, may fit but haven’t tried.
