Forum Replies Created
Viewing 20 posts - 1 through 20 (of 28 total)
  • in reply to: Rob Sorensen Coeur d’Alene Oonagh Build #50296
    Steve StoneSteve Stone
    Keymaster
    Wow, Rob. Just the shed is enough. Can’t wait to see the boat rowing and sailing.
    in reply to: Test sail success! #49152
    Keymaster
    Wow. Damn fine job Fred. Very impressed. I can feel the satisfaction from here.
    in reply to: Launch of the MUSKRAT #48946
    Keymaster
    Ah, yes, that’s it.  Nice addition.
    in reply to: Launch of the MUSKRAT #48944
    Keymaster
    I’m curious what the insert is on the starboard side of the center thwart?
    in reply to: Launch of the MUSKRAT #48943
    Keymaster
    Way to go, Fred. She’s a beauty and it looks like she’s being put to all kinds of good uses, including fishing and as a tender to the mothership.
    in reply to: Building ARRIBA in New Zealand #44892
    Keymaster
    Glad to say we have a CNC partner doing a great job on cutting and shipping kits in New Zealand now. Out of Opua in the Bay of Islands.
    in reply to: Thread suggestion #44244
    Keymaster
    Good suggestion Andrew. We will add it. Thank you.
    in reply to: Stepping the Mast & Bending the Sails #44243
    Keymaster
    Wow. Simply incredible. This was your very first build of a boat, correct?
    in reply to: Running Rigging question #43999
    Keymaster
    Hey Doug. See my new post on this topic “Rope” from Doug Hylan.
    in reply to: Edan launched in Connecticut #43996
    Keymaster
    Bravo Scott. Well done. Very inspiring for us all here at Off Center Harbor. Would love to see any/all good photos you have as you row/sail/motor her.
    in reply to: EXTERIOR FINISH #43929
    Keymaster
    Nice choices all around. Looking forward to seeing her in the water.
    in reply to: FINAL PAINT COLORS GOING ON! #43928
    Keymaster
    Well done, Doug. 135 days is impressive. You can’t go wrong with Kirby paints. They ARE indeed very nice people and Maynard Bray uses their paints. Hard to beat that combination.
    in reply to: 2nd COAT OF INTERIOR FINISH PAINT #43922
    Keymaster
    Fantastic, Doug. Very inspiring to see your progress and know she’ll be in the water soon.
    in reply to: Building ARRIBA in New Zealand #43712
    Keymaster
    Well done, John. Yes, please feel free to post your modifications.  This section would be a good place for that:
    ARRIBA / OONAGH – 14 – Bulkheads & Compartment
    in reply to: Tutorial Video – How to Use the Boatbuilders’ Forum #43595
    Keymaster
    Hi John.  Looks like you’ve figured it out.  We show how to upload photos in the tour video above.  One note, please try to post your info and photos under the correct/corresponding topic so your info matches the topic at hand.
    in reply to: Point Comfort #43594
    Keymaster
    Hi Bob. Great idea. Yes, IF you and your buddy building the 18 and the 23 would like to provide a fairly detailed forum discussion of your process with photos we’d be very glad, and grateful, to set up a forum for you.
    We’re trying to keep the forum very organized and structured for maximum benefit to those coming to it over the years ahead, so we’d ask that you send us a bullet point list of the significant steps in the process and we’ll set up the structure and away you go.
    You can look at the steps we have laid out for the ARRIBA as a rough example.
    Thanks,
    Steve
    in reply to: Preparing the Inner Hull #43557
    Keymaster
    Excellent Bob.  Since your boat will be stored outside, right side up on davits during the season, you might think about either a drain hole & plug at the lowest spot in the hull, or a cover.  Both have pros and cons.  The drain hole/plug is easiest (especially not have to deal with the cover every time you go out, and come back in, but the cover will save on sun/weathering.  A drain hole/plus, plus an easy/simple wrap-around sunbrella sail cover might be a good combo.  On our CY, I simply take the long zippered sail cover/bag and drape it over the rig and tie it on using the sail ties.  That allows quick/easy stowage and getting under way, protects the sail from the sun and rain, but also lets it breathe. That solution along with a drain plug would allow you to quickly stow the boat, lift it up on the davits, and walk away without worrying about a big rainstorm.  You’re probably way ahead on that thought but just putting it out there.
    in reply to: Fairing the Hull #43556
    Keymaster
    That’s really something Bob.  Well done.  And thanks for sharing your process and the photos. It’s another thing entirely to see a first time builder go at it, make a small error, and fix it with epoxy.  And see what looks to be a near-perfect boat coming along.
    in reply to: Gluing up the planks #43520
    Keymaster
    A heat gun and scraper can be used as the first action to get rid of the extra cured epoxy, and that will enable a quick easy sanding job that doesn’t cause the need for over aggressive sanding that creates an unfair “peak” across the plank where the epoxy was and “valleys” in the wood on each side of the epoxy joint (from the epoxy being harder than the soft wood when you’re sanding).  Take care not to get the joint too hot, and only heat the extra epoxy JUST enough to scrape it then let it cool as the heat gun will cause the epoxy within the joint to foul if you keep the heat on it too long.
    in reply to: Keel and Skeg #43519
    Keymaster
    Brilliant.  Well done, Bob.  Especially the documenting of the process with photos showing you doing the work.
